integer arithmetic
I'm getting weird results when I do integer division.
Frequency is being read in as 60 but the result being stored in var_1b /= 1e9/60 (~1.6E7). Instead the result reported by temp2 is 20522. The division for var_1a is performed correctly.
The offending code:
shared variable frequency: integer range 0 to 25000 :=0;
shared variable var_1a, var_1b, var_1c, var_1d: integer;
frequency := (to_integer(unsigned(Fin)));
var_1a := (1E9/pi_2);
var_1b := (1E9/(frequency));
temp <= std_logic_vector(to_unsigned(frequency, 16));
temp2 <= std_logic_vector(to_unsigned(var_1b, 16));
--- Quote Start ---
--- Quote End ---
Yes, that's expectable when you cast the divison result to 16 Bit unsigned. :(
At least 24 Bits are needed to hold the result.
That was the issue. Rookie mistake.
another apparent rookie mistake - the use of shared variables - why?
