17252 Discussions
launch Modelsim 10.1 in linux
I just installed the Modelsim 10.1 on ubuntu(12.10) but I don't what should I do to start the program!
The program is called 'vsim'.
At the command prompt, type 'which vsim' to see if the program path is known. If its not, then you need to
export PATH=$PATH:<path to modelsim installation>
and then try again.
Cheers,
Dave
