17254 Discussions
VHDL Syntax Questions - State Machine
Hello everyone, working on a class assignment and am struggling with VHDL syntax. I am getting the following error:
Error (10500): VHDL syntax error at SM_VHDL.VHD(79) near text "ELSE"; expecting ";"
So I know my issues has to do with my declaration of Z or Q.
This is a state-machine implementation with the following equations state equations:
  • Q1+ = X1*X0 + Q1*X1
  • Q2+ = |X1*|X0 + Q0*|X0
  • Z = Q1
To be honest, I'm not entirely sure what line 79 (the Q declaration) is accomplishing. Perhaps it is assigning the binary values to the states? The Z is a straightforward output declaration.
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.All; ENTITY SM_VHDL IS -- Do not modify this entity statement! PORT(X : IN STD_LOGIC_VECTOR(1 DOWNTO 0); RESETN, CLOCK : IN STD_LOGIC; Z : OUT STD_LOGIC; Q : OUT STD_LOGIC_VECTOR(1 DOWNTO 0) ); END SM_VHDL; -- Do not modify this entity statement! ARCHITECTURE behavior of SM_VHDL IS TYPE STATE_TYPE IS (A, B, C); SIGNAL state : STATE_TYPE; BEGIN PROCESS(CLOCK, RESETN) BEGIN IF RESETN = '0' THEN state <= A; ELSIF CLOCK'EVENT AND CLOCK = '1' THEN CASE state IS WHEN A => CASE X IS WHEN "00" => state <= B; END CASE; CASE X IS WHEN "01" => state <= A; END CASE; CASE X IS WHEN "10" => state <= A; END CASE; CASE X IS WHEN "11" => state <= C; END CASE; WHEN B => CASE X IS WHEN "00" => state <= B; END CASE; CASE X IS WHEN "01" => state <= A; END CASE; CASE X IS WHEN "10" => state <= B; END CASE; CASE X IS WHEN "11" => state <= C; END CASE; WHEN C => CASE X IS WHEN "00" => state <= B; END CASE; CASE X IS WHEN "01" => state <= A; END CASE; CASE X IS WHEN "10" => state <= C; END CASE; CASE X IS WHEN "11" => state <= C; END CASE; END CASE; END IF; END PROCESS; Z <= '1' WHEN state = A ELSE '0'; Q <= "00" WHEN state = A ELSE "01" ELSE "10"; END behavior;
This is the format that was given by the way:
Z <= '1' WHEN ... ELSE ...; Q <= "00" WHEN ... ELSE ... ELSE ...
Any help getting this compiled, and furthering my understanding would be greatly appreciated.
Hi
Q <= "00" WHEN ... ELSE ... else ... :oops:
You should write
Q <= "00" WHEN ... ELSE ... WHEN ... ELSE ...;
Thanks, I have changed it to this:
Z <= '1' WHEN state = A ELSE '0'; Q <= "00" WHEN state = A ELSE "01" WHEN state = B ELSE "10" WHEN state = C;
And I am now getting the following errors:
Error (10313): VHDL Case Statement error at SM_VHDL.VHD(25): Case Statement choices must cover all possible values of expression.
Each case takes into account all 4 binary combinations however... Hmm.
Update: Solved it, I had superfluous code in my case statements. Compiling now. Thanks for your assistance:
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.All; ENTITY SM_VHDL IS -- Do not modify this entity statement! PORT(X : IN STD_LOGIC_VECTOR(1 DOWNTO 0); RESETN, CLOCK : IN STD_LOGIC; Z : OUT STD_LOGIC; Q : OUT STD_LOGIC_VECTOR(1 DOWNTO 0) ); END SM_VHDL; -- Do not modify this entity statement! ARCHITECTURE behavior of SM_VHDL IS TYPE STATE_TYPE IS (A, B, C); SIGNAL state : STATE_TYPE; BEGIN PROCESS(CLOCK, RESETN) BEGIN IF RESETN = '0' THEN state <= A; ELSIF CLOCK'EVENT AND CLOCK = '1' THEN CASE state IS WHEN A => CASE X IS WHEN "00" => state <= B; WHEN "01" => state <= A; WHEN "10" => state <= A; WHEN "11" => state <= C; END CASE; WHEN B => CASE X IS WHEN "00" => state <= B; WHEN "01" => state <= A; WHEN "10" => state <= B; WHEN "11" => state <= C; END CASE; WHEN C => CASE X IS WHEN "00" => state <= B; WHEN "01" => state <= A; WHEN "10" => state <= C; WHEN "11" => state <= C; END CASE; END CASE; END IF; END PROCESS; Z <= '1' WHEN state = A ELSE '0'; Q <= "00" WHEN state = A ELSE "01" WHEN state = B ELSE "10" WHEN state = C; END behavior;
