led_driver
Can anyone help me determine that I have translated it all correct please?
original verilog
module led_driver (iRSTN, iCLK, iDIG, iG_INT2, oLED); input iRSTN; input iCLK; input iDIG; input iG_INT2; output oLED; //======================================================= // REG/WIRE declarations //======================================================= wire select_data; wire signed_bit; wire abs_select_high; reg int2_d; reg int2_count; reg int2_count_en; //======================================================= // Structural coding //======================================================= assign select_data = iG_INT2 ? iDIG : // +-2g resolution : 10-bit (iDIG?(iDIG?iDIG:5'h10):(iDIG?5'hf:iDIG)); // +-g resolution : 9-bit assign signed_bit = select_data; assign abs_select_high = signed_bit ? ~select_data : select_data; // the negitive number here is the 2's complement - 1 assign oLED = int2_count ? ((abs_select_high == 3'h0) ? 8'h18 : (abs_select_high == 3'h1) ? (signed_bit?8'h8:8'h10) : (abs_select_high == 3'h2) ? (signed_bit?8'hc:8'h30) : (abs_select_high == 3'h3) ? (signed_bit?8'h4:8'h20) : (abs_select_high == 3'h4) ? (signed_bit?8'h6:8'h60) : (abs_select_high == 3'h5) ? (signed_bit?8'h2:8'h40) : (abs_select_high == 3'h6) ? (signed_bit?8'h3:8'hc0) : (signed_bit?8'h1:8'h80)): (int2_count ? 8'h0 : 8'hff); // Activity always@(posedge iCLK or negedge iRSTN) if (!iRSTN) begin int2_count_en <= 1'b0; int2_count <= 24'h800000; end else begin int2_d <= {int2_d, iG_INT2}; if (!int2_d && int2_d) begin int2_count_en <= 1'b1; int2_count <= 24'h0; end else if (int2_count) int2_count_en <= 1'b0; else int2_count <= int2_count + 1; end endmodule
my vhdl:
--------------------------------------------------------------------------------- -- led_driver.vhd -- sindredit@gmail.com 16 Feb 2012 -- --------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity led_driver is -- Port ----------------------------------------------------------------------- -- Comes from other files or from the card port ( iCLK : in STD_LOGIC; -- CLOCK_50 iG_INT2 : in STD_LOGIC; -- G_SENSOR_INT iRSTN : in STD_LOGIC; -- NOT RESET iDIG : in STD_LOGIC_VECTOR(7 downto 0); -- CONTROL SIGNAL oLED : out STD_LOGIC_VECTOR(7 downto 0) -- OUT LEDS ); end; architecture struct of led_driver is -- SIGNALS SIGNAL select_data : STD_LOGIC_VECTOR(4 downto 0); SIGNAL signed_bit : STD_LOGIC; SIGNAL abs_select_high : STD_LOGIC_VECTOR(3 downto 0); SIGNAL int2_d : STD_LOGIC_VECTOR(1 downto 0); SIGNAL int2_count : STD_LOGIC_VECTOR(23 downto 0); SIGNAL int2_count_en : STD_LOGIC; -- START begin -- Output logic --oLed <= signalsoLed; oLED(2) <= '1'; -- Should we reset? process(iCLK, iRSTN) begin IF ((NOT(iRSTN)) = '1') THEN int2_count_en <= '0'; int2_count <= "100000000000000000000000"; ELSIF (iCLK'EVENT AND iCLK = '1') THEN int2_d <= (int2_d(0) & iG_INT2); IF (NOT(int2_d(1)) AND int2_d(0)) THEN int2_count_en <= '1'; int2_count <= "000000000000000000000000"; ELSIF ((int2_count(23)) = '1') THEN int2_count_en <= '0'; ELSE int2_count <= int2_count + "000000000000000000000001"; END IF; END IF; end process; end struct;
