license problem
Hi ,
i download the full version of Quartus 64 bit from Altera website .
i have license for this version from Altera until 08/05/14 .
Quartus works fine until yesterday and for some reason the compilation doesn't work for my project and there is error :
"specified license was not valid for this machine
full compilation was unsuccessful "
under License Setup :
At License type : Full license
At Expiration : 08-May-2014 .
what may cause this issue and how can i solve it ?
attached file .
Did you change your hard drive or network card? AFAIK Quartus uses serial numbers from those two for the license key. If you change one of those you will probably have to ask your FAE for a new license file.
