lmgrd and alterad
Hi all,
I am having some problems with alteard vendor daemon. The debug.log and diagnostics are all fine except, when I try to compile, it says feature compiler not supported by license. I am having a floating pc license for 25 users. When I do a lmutil lmstat -a -c 28500@lecpc403 (port@server) I get the following message:
C:\altera\70\quartus\bin>lmutil lmstat -a -c 28500@lecpc403
lmutil - Copyright (c) 1989-2003 by Macrovision Corporation. All rights reserved
Flexible License Manager status on Fri 5/11/2007 11:09
[Detecting lmgrd processes...]
License server status: 28500@lecpc403
License file(s) on lecpc403: C:\Altera\Alteralic5April.dat
lecpc403: license server UP (MASTER) v9.2
Vendor daemon status (on lecpc403):
alterad: UP v9.2
Feature usage info:
Users of quartus: (Error: 25 licenses, unsupported by licensed server)
Users of maxplus2: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_0012: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_0014: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_0055: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_00A7: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_00A8: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_00A4: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_0034: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_00AC: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_00AD: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_00BE: (Error: 25 licenses, unsupported by licensed server)
Users of 6AF7_00BF: (Error: 25 licenses, unsupported by licensed server)
Users of maxplus2verilog: (Error: 25 licenses, unsupported by licensed serve
Users of maxplus2vhdl: (Error: 25 licenses, unsupported by licensed server)
Any idea? Any pointer is greatly appreciated.
Hi there,
I have have had a similar problem myself, As a first hit I would update your daemons to 9.5 (lmgrd, alterad, and mgcld etc) this may help. These are the lateset and are in the new 7.1 release which is available on the www. Failing that just the deamons are normally avaiable in the downloads section on altera.com, although these may not have been updated yet.
Are there any errors in the debug log from your license server? Perhaps you could cut and paste it in the thread.
Thanks for your reply. I have extracted the relevant daemons from 7.1 but the situation has not change except the V9.2 now read V9.5.
The following is the output of debug log:
14:29:38 (lmgrd) -----------------------------------------------
14:29:38 (lmgrd) Please Note:
14:29:38 (lmgrd)
14:29:38 (lmgrd) This log is intended for debug purposes only.
14:29:38 (lmgrd) There are many details in licensing policies
14:29:38 (lmgrd) that are not reported in the information logged
14:29:38 (lmgrd) here, so if you use this log file for any kind
14:29:38 (lmgrd) of usage reporting you will generally produce
14:29:38 (lmgrd) incorrect results.
14:29:38 (lmgrd)
14:29:38 (lmgrd)
14:29:38 (lmgrd)
14:29:38 (lmgrd) Done rereading
14:29:38 (lmgrd) FLEXlm (v9.50) started on LECPC403 (IBM PC) (5/17/2007)
14:29:38 (lmgrd) Copyright (c) 1988-2004 by Macrovision Corporation. All rights reserved.
14:29:38 (lmgrd) US Patents 5,390,297 and 5,671,412.
14:29:38 (lmgrd) World Wide Web: http://www.macrovision.com
14:29:38 (lmgrd) License file(s): C:\Altera\Alteralic5April.dat
14:29:38 (lmgrd) lmgrd tcp-port 1800
14:29:38 (lmgrd) Starting vendor daemons ...
14:29:38 (lmgrd) Started alterad (pid 1608)
14:29:38 (lmgrd) alterad using TCP-port 4723
-jul-2038
14:29:38 (alterad) Warning: maxplus2 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_0012 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_0014 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_0055 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00A7 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00A8 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00A4 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_0034 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00AC expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00AD expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00BE expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00BF expires 31-jul-2038
14:29:38 (alterad) Warning: maxplus2verilog expires 31-jul-2038
14:29:38 (alterad) Warning: maxplus2vhdl expires 31-jul-2038
14:29:38 (alterad) Server started on LECPC403
Will try rebooting in a while but I am not giving much hope
Just rebooted. No difference. The lmtools.exe diagnostics gives a Flexlm Error of -18,147.
Hello
Humm the output seems rather odd, you should not be seeing the * expires in XXX messages. I would download a clean licnese file from Altera.com, just edit the server name, port and demon lines (to point to 9.5) and then see what happens.
NB on Windows only use notepad to do the edits, wordpad etc can screw up the license.
If you still see a problem then I think you should submit an issue via MySupport on altera.com so someone can take a closer look. (I don't think you should upload your license file here, but this is needed to look further).
Also the post reboot license log would be good to see if you can paste it in.
After weeks of fiddling, I think I am coming close to the answers. The expiry date 1-JUL-2038 is not supported by Windows OS. According to numerous posts, all 32 bit machines can only support up to 29-JAN-2038.
Have requested a new license from Altera, will update everyone when I verify this.
cheers,
wongmld
