17257 Discussions
make: Leaving directory '/usr/src/linux-headers-5.4.0-1031-azure' Cannot find JTAG cable.
NSVR
Hi
I am trying to setup FPGA , I am able to install quartus prime software with devices and in next step  I am following the below link where we were asked to run fpga_install.sh but  when I am running the same I am getting this error.
make: Leaving directory '/usr/src/linux-headers-5.4.0-1031-azure' Cannot find JTAG cable. Aborting installation
https://docs.openvinotoolkit.org/2020.3/_docs_install_guides_VisionAcceleratorFPGA_Configure.html
AnilErinch_A_Intel
Hi ,
Please let us know that whether a jtag or usb-jtag cable has been properly to the board,
You can use the below link as a reference
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2018/why-do-i-get-the-error-no-jtag-hardware-available-when-running-j.html
Please let us know the feedback.
Thanks and Regards
Anil
NSVR
I am doing setup in Azure vm. so there is no scope to check "whether a jtag or usb-jtag cable has been properly to the board" or we should assume that was plugged properly.
I have tried you link as well. but no use
AnilErinch_A_Intel
Hi ,
Please let us know the results obtained after running the jtagconfig,
You may also have to explore on how the devices work in the Azure VM.
Thanks and Regards
Anil
