max 300 process
hi
i have a problem with my altera max device.
it does not enter into the process despite the constantly updated clock:
q<=q_temp;
ff: process(clk)
begin
IF (clk'event) AND (clk='1') and (en='1') THEN -- Positive Edge
q_temp <= d;
elsif (en='0') then q_temp<=q_temp;
END IF;
if (reset='1') then
q_temp <='0';
end if;
end process;
thanks
It seems to me, that you actually meaned to code the below process:
ff: process(clk) IF (reset='1') THEN q_temp <='0'; ELSIF (clk'event) AND (clk='1') THEN -- Positive Edge IF en='1' THEN q_temp <= d; ELSE q_temp<=q_temp; END IF; END IF; end process;
but the code inside the process isn't executed.
The device doesn't come in the process.
i test the code that you have sent me!!! soon
I assumed, that Quartus would possibly misunderstand the asynchronous (outside clock edge) hold condition
But I verified, that both variants exactly infer a DFFE primitive in mapped design. So if everything seems wrong, it's most likely a simulation problem. The code behaves as a D-Flip-Flop with clock enable, as it should.
i have built the project and programmed the device but doesn't work!
could be a hardware problem on the clock?
sure that the CPLD covering the process statement?
I inserted a quartz gclk1 at 8 MHz (pin 43)! without capacitors
thank's
--- Quote Start ---
--- Quote End ---
Yes, can you verify that the clock is actually present?
the clock works! I made a program to test it, even if it behaves erratically. Oscillates only if I get close! Where can I find a pattern for the clock?
I made an asynchronous circuit with a process statement!
the process is update by a pin connected to an external switch.
Not work
ther is another problem.
does not recognize initial allocations. For example:
signal a:std_logic:='0'
however i renew my request:
