17255 Discussions
QII Web compile: err Incremental compilation
QII Web V9.1 no sp, Build 222 Oct 21, 2009
I just converted files from QII Web V7 and the first compile was fine. Created SigTap, programmed device and all.
Then I created the SigTap file and recompile. Gets the error:
Quote:
Error: Current license file does not support incremental compilation
Next I restarted the project & compiled. Same error.
Then I un-clicked the SigTap & recompiled. Same error.
Checked the current assignments for the Compiler; Incremental is grayed out as expected.
Is this perhaps a bug that was fixed in QII V9.1 SP1?
Can anyone suggest how to proceed?
Thanks for the support....
btw: I am downloading SP1 but will take about 8 hours!! Slow connection...
Try deleting the db and incremental_db folders from your project directory and then recompile.
Thx Kevin,
Deleted both folders - same problem.
It seems as if I activated the post fit netlist during the Signal Tap - should have answered NO to the prompt, and that is what caused all the hassles.
Thanks for the feedback - resolved.
