multiply IP Stratix 10
jjxichn
初学者
534 次查看
Hello All, I am using Stratix 10 to do some interesting stuff. When I used fixed point functions FPGA IP to do multiplication of two 4 bits unsigned number, it shows it using DSP blocks and I did not see any options to disable DSP blocks. I am wondering is there any ways to realize this multiplication using LUTs only? Thanks.
标签 (1)
0 项奖励
1 解答
FvM
名誉分销商 II
485 次查看
using Fixed Point IP for 4-Bit numbers? Why don't you use
lpm_mult IP, or simply infer multiplier from HDL code.
Frank
在原帖中查看解决方案
0 项奖励
1 回复
FvM
名誉分销商 II
486 次查看
Frank
0 项奖励
回复
