17255 Discussions
need more infomation about TimeQuest
I hope to implement the following calculation in TimeQuest's *.sdc file, set ad_clock_period 80
set ad_sclk_board_delay_max 5
set ad_sclk_board_delay_min 3
set ad_data_board_delay_max 5
set ad_data_board_delay_min 3
set ad_data_tco_max 2
set ad_data_tco_min 1
set max_delay $ad_clock_period/2 + $ad_sclk_board_delay_max + $ad_data_board_delay_max + $ad_data_tco_max
set min_delay $ad_clock_period/2 + $ad_sclk_board_delay_min + $ad_data_board_delay_min + $ad_data_tco_min
But after *.sdc being reading into TimeQuest, error occur:
Error: wrong# args: should be "set varName ?newValue?"
while executing
"set max_delay $ad_clock_period/2 + $ad_sclk_board_delay_max + $ad_data_board_delay_max + $ad_data_tco_max"
(file "E:/Altera_Project/QuartusII/FreqMeasure/FreqMeasure_AvalonInterface.sdc" line 190)
Any response will be very appreciated.
To do calculations you have to use the expr command within square brackets:
set a 2.0
set b 3.0
set c [expr $a + $b]
So expr calculates the value, and the square brackets mean execute the commands inside and use their returned value.
Finally, I recommend using decimals for all numbers. In Tcl, integer types are handled differently than decimals, so:
expr 5 / 2
will return 2, not 2.5. (Dumb, I know, but it's part of the Tcl language...)
Thanks...
That will be a good start to learn tcl :)
