- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
good afternoon people. I'm a newbie in vhdl and i have problems about test bench. My area director has left me some problems. If anyone could help me with logs and the last two problems.
the link is as follows http://users.ictp.it/~fpga/2006/exercises/lab-trieste2006-parta.pdfLink kopiert
5 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
What exactly is the problem? Have you attempted the problems yourself?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Probably some specific examples or error that you observed with test bench would be helpful for understanding your issue.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
one of my problems about test bench is the next: Design and Simulate a 12-Bit Magnitude Comparator using a cascade of three 74F85
4-Bit Magnitude ComparatorsVHDL CODE (COMPILE GOOD)
library ieee;
use ieee.std_logic_1164.all;
entity comparador_12 is
port( num1 : in std_logic_vector(3 downto 0);
num2 : in std_logic_vector(3 downto 0);
menor : out std_logic;
igual : out std_logic;
mayor : out std_logic
end comparador_12;
architecture behavioral of comparador_12 is
begin
process(num1,num2)
begin
if (num1&num1&num1 > num2&num2&num2 ) then
menor <= '0';
igual <= '0';
mayor <= '1';
elsif (num1&num1&num1 < num2&num2&num2) then
menor <= '1';
igual <= '0';
mayor <= '0';
else
menor <= '0';
igual <= '1';
mayor <= '0';
end if;
end process;
end behavioral;
TEST BENCH
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity comparador_12_tb is
end comparador_12_tb;
architecture behavior of comparador_12_tb is
--declaro mis señales de entrada
signal num1,num2 : std_logic_vector(3 downto 0) :=(others => '0');
signal menor,igual,mayor : std_logic:='0';
begin
--instancia de entidad
UUT : work.comparador_12 port map(num1,num2,menor,igual,mayor);
--definicion del estimulo de proceso
tb : process
begin
num1&num1&num1<="100111000100"; --num1 = 2500
num2&num2&num2<="111011011000"; --num2 = 3800
wait for 10 ns;
num1&num1&num1<="100110011001"; --num1 = 2457
num2&num2&num2<="010111100011"; --num2 = 1507
wait for 10 ns;
num1&num1&num1<="111111111111"; --num1 = 4095
num2&num2&num2<="111111111111"; --num2 = 4095
wait for 10 ns;
num1&num1&num1<="100010001000"; --num1 = 2184
num2&num2&num2<="001101110111"; --num2 = 887
wait;
end process tb;
end;
when compile with tb i have 10 errores. The next is Error (10500): VHDL syntax error at comparador_12_tb.vhd(19) near text "&"; expecting "(", or "'", or "."
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Please post your code in code tags next time.
You cannot use '&' to make a vector you assign to. Either split the bit pattern or use ',' instead of the ampersand. [edit]See this thread for things to watch out for if you are using the latter. http://www.alteraforum.com/forum/showthread.php?t=25484 [/edit] (http://www.alteraforum.com/forum/showthread.php?t=25484)- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
You cant do what you are trying to do. you're trying to assign the same signal with 3 different bit patterns.
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
