17255 Discussions
not understand compile error message
dsun01
New Contributor III
Dear Support/Expert,
I got the following message while I am opening a .qsys file.
is there a document or a link explain how to fill in the parameters of this command?
set filesList [list]; foreach_in_collection file [get_all_assignments -type global -name IP_FILE] { append filesList [get_assignment_info $file -value]\; }; return $filesList;
how to dealing with the following error messages.
Error: set_global_assignment -name IP_FILE ../ip/ip/jesd204b/jesd204b_jesd_top_qsys_0.ip
thank you,
David Sun
------------------------------------------------------------- original error message
Error: Failed to retrieve source file from Quartus project, manually re-run the following commands in Quartus tcl shell.
Error: set filesList [list]; foreach_in_collection file [get_all_assignments -type global -name IP_FILE] { append filesList [get_assignment_info $file -value]\; }; return $filesList;
Error: set filesList [list]; foreach_in_collection file [get_all_assignments -type global -name QSYS_FILE] { append filesList [get_assignment_info $file -value]\; }; return $filesList;
Error: Failed to add source file to Quartus project, manually re-run the following commands in Quartus tcl shell.
Error: set_global_assignment -name IP_FILE ../ip/ip/jesd204b/jesd204b_enc_data_gen_0.ip
