opencl compile error
Hi, I'm a student who has the problem with compiling openCL.
my Quartus and Altera OpenCL SDK version is 16.0
What the problem is that if i try to compile such as
: aoc device/boardtest.cl --sw-dimm-partition -o bin/device boardtest.aocx
the Error message shows like that
Error: aoc: Executable C:/altera/16.0/hld/windows64/bin/aocl-clang exists but is not working!
The cause of failure cannot be determined. Run executable manually and watch for error message.
I set the User Environment variable, License, and reinstalled the application. but I have the same error message.
Is there anyone else who have the same problem like me?
https://alteraforum.com/forum/attachment.php?attachmentid=14421&stc=1
could you check the user permission and access right?
If you try to compile a normal Hello world. is that works?
CloseCL
(This message was posted on behalf of Intel Corporation)
I already checked the user permission and access right.
also, I use command prompt(Administrator), but it doesn't work..
I don't know what the problem is
