17267 Discussions
pin assignment - unused GPIO pins
Hi there,
I´m using the GPIO pin header of the DE2 - 115.
I´m finished with the pin assignment, but there are several pins unused. But i don`t want to have them floated, so i want to define them.
I already read, that it is possible to connect them via 0 ohm resistor to gnd or Vcc. But in that case, they used a standard routing file from altera.
I cannot use this file, but i want to define the gpio pins completely, to avoid damaging the board and the connected module.
Is it possible to:
- find the unused pins automatically
- define their states, but without using them in the project
or is it necessary to include I/O pins in the project to assign the unused pins to a state?
Perhaps there is an other way to assign unused pins?
Thank you in advance.
kind regards
You have two options;
1. Define all pins used in a schematic as port in your top-level HDL file, and drive them with valid values.
2. Use the device option to "tri-state unused pins", or "enable weak pull-up on unused pins"
Given that a design may not use all FPGA pins on a device, I generally use both options.
Run the scripts associated with this DE0-nano design
http://www.alteraforum.com/forum/showthread.php?t=45927
and you'll see an example of;
1. A top-level design file that includes all I/O pins used on the DE0-nano board
2. A constraints.tcl script that assigns all the pins on the top-level, and some default constraints (including the weak pull-ups on unused pins constraint).
3. A synthesis script synth.tcl that automates the build.
This approach allows me to create a new project by copying the top-level HDL and synth.tcl script, making a few minor path adjustments for the new project, and then synthesize a new design.
I never have to worry about whether I have forgotten to assign pins correctly.
Cheers,
Dave
