hey all.
i am trying use modelsim altera to perform post-synthesis simulation of my design synthesized in quartus II. These are the steps i am doing: i) perform analysis&synthesis of my design in quartus ii) complie the testbench(which i have written), the .vo file(generated during analysis&synthesis), and the cycloneii_atoms.v file(which is provided in the libraries) in modelsim. (i am using cyclone II device family) iii) start simulation & selecting the testbench module for simulation. the error comes while loading the cycloneii.v this verilog file contains a number of modules. the error is for one of the modules and it is like this(within 'quote&unquote'): quoting the error: # ** Error: (vsim-3389) D:/AnuChaudhary/Study/Project/Quartus/24Septonwards/loopacc/simulation/modelsim/cycloneii_atoms.v(5764): Port '(null)' not found in the connected module (1st connection). # Region: /testbench_MOD/loop_accelerator/\CLK~I\/outreg_D_mux unquoting it. (TO EXPLAIN - testbench_MOD is the top level module in my testbench, and the testbench is testing the working of my loop_accelerator design. the "outreg_D_mux is in cycloneii.v, and is an instantiation of a mux module in cycloneii.v) infact there are 7 such errors, and in the end it says the following &stops: # ** Fatal: (vsim-3365) D:/AnuChaudhary/Study/Project/Quartus/24Septonwards/loopacc/simulation/modelsim/cycloneii_atoms.v(5764): Too many port connections. Expected 4, found 11. can anyone help me understand what is going on exactly? thanks, -anuLink Copied
You don't need to compile cycloneii_atoms.v if you're using Modelsim-Altera. It has already been pre-compiled. You just need to specify the pre-compiled library using the -L switch
Example: vsim -t 1ps -L cycloneii_ver -L work my_tb cycloneii_ver is the pre-compiled library for cycloneii_atoms.v Also, FYI in case you're not aware that the VO file is not generated by default if you just run Analysis & Synthesis. It is only generated by default during full compilation. You required to run it manually in different flow. You can refer to "Generating a Post-Synthesis Simulation Netlist" in the Modelsim Handbook. Hope it helps.- Mark as New
hey...thanks!
but i am still getting the same error.- Mark as New
How is your simulation script looks like?
it looks like this:
transcript on if {[file exists gate_work]} { vdel -lib gate_work -all } vlib gate_work vmap work gate_work vlog -vlog01compat -work work +incdir+. {loopaccelerator.vo} vlog -vlog01compat -work work +incdir+D:/AnuChaudhary/Study/Project/Quartus/24Septonwards/loopacc/synth_result {D:/AnuChaudhary/Study/Project/Quartus/24Septonwards/loopacc/synth_result/testbench_mod.v} vsim -t 1ps -L cycloneii_ver -L gate_work -L work testbench_MOD add wave * view structure view signals run -all- Mark as New
just for completeness, i am giving the whole list of commands( shown within modelsim) when i start simulation from within quartusII (via EDA Simulation Tool --> Run Gate level Simulation ):
Reading C:/altera/71sp1/modelsim_ae/tcl/vsim/pref.tcl # do loopaccelerator_run_msim_gate_verilog.do # if {[file exists gate_work]} { # vdel -lib gate_work -all # } # vlib gate_work # vmap work gate_work # Copying C:\altera\71sp1\modelsim_ae\win32aloem/../modelsim.ini to modelsim.ini # Modifying modelsim.ini # ** Warning: Copied C:\altera\71sp1\modelsim_ae\win32aloem/../modelsim.ini to modelsim.ini. # Updated modelsim.ini. # # vlog -vlog01compat -work work +incdir+. {loopaccelerator.vo} # Model Technology ModelSim ALTERA vlog 6.1g Compiler 2006.08 Aug 12 2006 # -- Compiling module LoopAccelerator # # Top level modules: # LoopAccelerator # # vlog -vlog01compat -work work +incdir+D:/AnuChaudhary/Study/Project/Quartus/24Septonwards/loopacc/synth_result {D:/AnuChaudhary/Study/Project/Quartus/24Septonwards/loopacc/synth_result/testbench_mod.v} # Model Technology ModelSim ALTERA vlog 6.1g Compiler 2006.08 Aug 12 2006 # -- Compiling module testbench_MOD # # Top level modules: # testbench_MOD # # vsim -t 1ps -L cycloneii_ver -L gate_work -L work testbench_MOD # vsim -L cycloneii_ver -L gate_work -L work -t 1ps testbench_MOD # // ModelSim ALTERA 6.1g Aug 12 2006 # // # // Copyright 2006 Mentor Graphics Corporation # // All Rights Reserved. # // # // THIS WORK CONTAINS TRADE SECRET AND # // PROPRIETARY INFORMATION WHICH IS THE PROPERTY # // OF MENTOR GRAPHICS CORPORATION OR ITS LICENSORS # // AND IS SUBJECT TO LICENSE TERMS. # // # Loading gate_work.testbench_MOD # Loading gate_work.LoopAccelerator # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_lcell_ff # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_lcell_comb # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_io # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_mux21 # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_dffe # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_asynch_io # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_clkctrl # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_mux41 # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_ena_reg # ** Error: (vsim-3043) D:/AnuChaudhary/Study/Project/Quartus/24Septonwards/loopacc/synth_result/testbench_mod.v(56): Unresolved reference to '_processor_0_done' in loop_accelerator._processor_0_done. # Region: /testbench_MOD # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.CYCLONEII_PRIM_DFFE # ** Warning: (vsim-3620) C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v(104): Specify path destination port 'Q' has no drivers on it. # Region: /testbench_MOD/loop_accelerator/\CLK~I\/input_reg # ** Error: (vsim-3389) C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v(5764): Port '(null)' not found in the connected module (1st connection). # Region: /testbench_MOD/loop_accelerator/\CLK~I\/outreg_D_mux # ** Error: (vsim-3389) C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v(5764): Port '(null)' not found in the connected module (2nd connection). # Region: /testbench_MOD/loop_accelerator/\CLK~I\/outreg_D_mux # ** Error: (vsim-3389) C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v(5764): Port '(null)' not found in the connected module (3rd connection). # Region: /testbench_MOD/loop_accelerator/\CLK~I\/outreg_D_mux # ** Error: (vsim-3389) C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v(5764): Port '(null)' not found in the connected module (4th connection). # Region: /testbench_MOD/loop_accelerator/\CLK~I\/outreg_D_mux # ** Error: (vsim-3389) C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v(5764): Port '(null)' not found in the connected module (5th connection). # Region: /testbench_MOD/loop_accelerator/\CLK~I\/outreg_D_mux # ** Error: (vsim-3389) C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v(5764): Port '(null)' not found in the connected module (6th connection). # Region: /testbench_MOD/loop_accelerator/\CLK~I\/outreg_D_mux # ** Error: (vsim-3389) C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v(5764): Port '(null)' not found in the connected module (7th connection). # Region: /testbench_MOD/loop_accelerator/\CLK~I\/outreg_D_mux # ** Fatal: (vsim-3365) C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v(5764): Too many port connections. Expected 4, found 11. # Time: 0 ps Iteration: 0 Instance: /testbench_MOD/loop_accelerator/\CLK~I\/outreg_D_mux File: C:/altera/71sp1/modelsim_ae/win32aloem/../altera/verilog/src/cycloneii_atoms.v # FATAL ERROR while loading design # Error loading design # Error: Error loading design # Pausing macro execution # MACRO ./loopaccelerator_run_msim_gate_verilog.do PAUSED at line 12- Mark as New
"loopaccelerator_run_msim_gate_verilog.do" is the simulation script file I have pasted in the message before the last one.
in this file, line 12 corresponds to this line: vsim -t 1ps -L cycloneii_ver -L gate_work -L work testbench_MOD- Mark as New
Looking at the error's, it leads me to believe that there may be a problem with your testbench? What you can do is load your *.vo file independent of your testbench. If you can load the *.vo file then this would probably rule out the possibility that there is a problem with the Q II netlist generation of the *.vo and any problems relating to the cycloneii library.
Here's the command to load the .vo: vsim -L cycloneii_ver -L gate_work -L work loopaccelerator (I'd run Modelsim-Altera independent of the Quartus II software to test this case). Additionally, were you able to perform a RTL (functional) simulation without using NativeLink to invoke the ModelSim-Altera simulator? Try the above and post your results... Good luck! --pld_wiz- Mark as New
thanks pld_wiz! here are the results:
1. when i try doing "vsim -L cycloneii_ver -L gate_work -L work work.LoopAccelerator", everything loads fine. # vsim -L cycloneii_ver -L gate_work -L work work.LoopAccelerator # Loading work.LoopAccelerator # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_lcell_ff # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_lcell_comb # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_io # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_mux21 # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_dffe # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_asynch_io # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_clkctrl # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_mux41 # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.cycloneii_ena_reg # Loading C:\altera\71sp1\modelsim_ae\win32aloem/../altera/verilog/cycloneii.CYCLONEII_PRIM_DFFE 2. when i perform RTL simulation 'with' using Native link to invoke modelsim altera, my testbench works correctly & this is a part of what i get in the response window of modelsim: -- Compiling module testbench_MOD # # Top level modules: # testbench_MOD # # vsim -t 1ps -L lpm_ver -L altera_ver -L altera_mf_ver -L sgate_ver -L cycloneii_ver -L rtl_work -L work testbench_MOD # vsim -L lpm_ver -L altera_ver -L altera_mf_ver -L sgate_ver -L cycloneii_ver -L rtl_work -L work -t 1ps testbench_MOD # // ModelSim ALTERA 6.1g Aug 12 2006 # // # // Copyright 2006 Mentor Graphics Corporation # // All Rights Reserved. # // # // THIS WORK CONTAINS TRADE SECRET AND # // PROPRIETARY INFORMATION WHICH IS THE PROPERTY # // OF MENTOR GRAPHICS CORPORATION OR ITS LICENSORS # // AND IS SUBJECT TO LICENSE TERMS. # // # Loading rtl_work.testbench_MOD.......(loads other files&finishes correctly) >>>>>> so here, the vsim command has a number of libraries included (lpm_ver, altera_ver...etc) 3. if i perform a rtl simulation 'without' using Native link to invoke modelsim altera, everything is running fine Just to make sure that i am doing the rtl simulation directly thru modelsim correctly, these are the steps i am taking : >i creat a new project > add my testbench.v and other verilog design files to this project (i do not add loopaccelerator.vo) > then i simulate using "vsim work.testbench_MOD" >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>. do u see some relation now?- Mark as New
Hi Anu,
For Cyclone II gate-level simulation, all you need to do in Modelsim-Altera software to specify the Cyclone II library is as follows: "-L cycloneii_ver". For gate-level simulation, this is the only library that is required. Since you were able to load the *.vo by itself, I believe that there is a mis-match between the testbench and the *.vo netlist generated by the Q II software. You may want to double check the port map of the .vo against the testbench. You may want to try using the latest version of the Q II software ver 7.2 and Modelsim-Altera 6.1g (for Q II 7.2) to see if the problem still exist? If 7.2 generates the same errors, then I'd inquire with the Altera Technical Support staff to see if they can help you find a resolution. Good luck and please post what you find... it'll be helpful for me in case i should run into this in the future!! pld-wiz- Mark as New
figured out what the problem was....i was sampling one of the internal wires in my testbench. since it was not a port so was not visible outside the module. therefore the mismatch during post-syn simulation.
thanks for all the pointers! -anu- Mark as New
Anu,
I'm glad you were able to resolve the issue! -pld_wiz
