17267 Discussions
Verilog error. Supposedly can't find pin, but it's there
Hi, I'm using the Max+Plus II suite to develop a Verilog project. I have an annoying problem, which I have reduced to the following toy example.
I have one file mini.v (which compiles flawlessly) containing the following.
module mini( data, clock, exit); input data, clock; output exit; reg exit; always @ (posedge clock) begin if (data == 0) exit= 2'b11; end endmodule
I also have this file maxi.v.
module maxi( A, B, rlj, C); input A, B, rlj; output C; reg C; mini M1 (.data(A), .clock(rlj), .exit(C) ); endmodule
When I try to compile this, it gives the following error.
error: can't find a pin in the design file that corresponds to pinstub/port 'exit' in the symbol, function prototype, or other construct 'm1' that represents the file.
I can't understand why is there a problem, since I'm passing the M1 instance 'C' as a pin for 'exit'.
Thanks in advance for any comment you might provide.
Probably because your maxi module doesn't declare the C output correctly, should be:
input A, B, rlj;
output [1:0] C;
wire [1:0] C;
Thanks a lot!!
I changed both instances of "output ..." to "output [1:0]" and now it works! thanks a lot again
