- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi, I'm using the Max+Plus II suite to develop a Verilog project. I have an annoying problem, which I have reduced to the following toy example.
I have one file mini.v (which compiles flawlessly) containing the following.module mini( data, clock, exit);
input data, clock;
output exit;
reg exit;
always @ (posedge clock) begin
if (data == 0) exit= 2'b11;
end
endmodule
I also have this file maxi.v.
module maxi( A, B, rlj, C);
input A, B, rlj;
output C;
reg C;
mini M1 (.data(A), .clock(rlj), .exit(C) );
endmodule
When I try to compile this, it gives the following error. error: can't find a pin in the design file that corresponds to pinstub/port 'exit' in the symbol, function prototype, or other construct 'm1' that represents the file. I can't understand why is there a problem, since I'm passing the M1 instance 'C' as a pin for 'exit'. Thanks in advance for any comment you might provide.
Link kopiert
2 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Probably because your maxi module doesn't declare the C output correctly, should be:
module maxi( A, B, rlj, C); input A, B, rlj; output [1:0] C; wire [1:0] C;- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks a lot!!
I changed both instances of "output ..." to "output [1:0]" and now it works! thanks a lot again
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
