17263 Discussions
problem with Clock Constraint 3 bit modulo 5 counter
Dear Guru,
You may refer to the link as I posted the same question before at:
Forum > Coding Questions > Verilog and System Verilog > simple Infinite loop expansion header using Altera DE2-70 Cyclon ii
I am using Altera DE2-70 with Quartus II Free Web Edition.
I tried to build 3-Bit modulo 5 counter. However, the clock signal is not regenerate smoothly and the flip-flop logic seem different.Herewith I attach the picture of the signals. From bottom; D0 (GPIO_0[0]), D1 (GPIO_0[1]), D2 (GPIO_0[2]), D3 (GPIO_0[3]) and D7 (GPIO_0[7]) at top.
https://www.alteraforum.com/forum/attachment.php?attachmentid=7087
Its generate from .bdf, .v and .sdc
https://www.alteraforum.com/forum/attachment.php?attachmentid=7088
module bitmodulo5( CLOCK_50, GPIO_0, VCC ); input CLOCK_50; input VCC; output GPIO_0; assign GPIO_0 = CLOCK_50; assign GPIO_0 = VCC; // Instantiation: JKFF JKFF_inst (.j(GPIO_0), .k(GPIO_0), .clk(CLOCK_50), .clrn(GPIO_0), .prn(GPIO_0), .q(GPIO_0)); JKFF JKFF_inst1 (.j(GPIO_0), .k(GPIO_0), .clk(CLOCK_50), .clrn(GPIO_0), .prn(GPIO_0), .q(GPIO_0)); JKFF JKFF_inst2 (.j(GPIO_0), .k(GPIO_0), .clk(CLOCK_50), .clrn(GPIO_0), .prn(GPIO_0), .q(GPIO_0)); endmodule
#Constrain the base clock create_clock -add -period 10.000 -waveform { 0.000 5.000 } -name CLOCK_50 # Constrain the divide by 2 register clock create_generated_clock -add -source CLOCK_50 -name div2clock -divide_by 2 -master_clock CLOCK_50 create_generated_clock -add -source CLOCK_60 -name div2clock -divide_by 2 -master_clock CLOCK_50 create_generated_clock -add -source CLOCK_70 -name div2clock -divide_by 2 -master_clock CLOCK_50 report_ucp -summary
I know there is something wrong with my Clock Constraint. The execution done without error. Which part should I do to generate smooth clock and correct flip-flop logic? Thank you in advance!
I already figured out the answer for my question. There is a good example and tutorial on how to build a simple 3bit modulo counter :
http://hep-outreach.uchicago.edu/samples/3bit_counter/
The only problem is because I am using the free version therefore I cannot make the .vwf file. I am looking for the license and seem university license may help solving the problem.
