17255 Discussions
problem with my code (Error 10500)
Error (10500): VHDL syntax error at jksmealy.vhd(52) near text "CASE"; expecting "if"
Error (10500): VHDL syntax error at jksmealy_valmis.vhd(55) near text "WHEN"; expecting ";"
Error (10500): VHDL syntax error at jksmealy.vhd(60) near text "WHEN"; expecting ";"
Error (10500): VHDL syntax error at jksmealy.vhd(65) near text "WHEN"; expecting ";"
Here is the error message what i don't understand and
the code file is attached
Thank for any help u can give :) Solved :)
Try this:
elsif clk'event ...
instead of else if
applies to other else ifs down...
