17255 Discussions
video and image processing
with video and image processing megacore function is it possible to show real time video with de2 board
What do you mean by showing a video and on what to show it? On a host PC or on a VGA connected to the board?
i want to connect a cmos camera to the video in of de2 board and a monitor to the vga port of the board,so that i can display the video through vga to the monitor.so with video and image processing megacore function is it possible or not.
the camera detail is attached
--- Quote Start ---
--- Quote End ---
Regardless of the Camera you are connecting, you can create a displaying channel (using the video sync generator for example). This means that you have to build your own displaying system.
I don't know what's exactly your application is, but here you some documentations that may help:
http://www.altera.com/literature/hb/nios2/qts_qii55006.pdf
http://www.altera.com/literature/dc/2007/c3b.pdf
http://www.qtl.co.il/img/copy.png
