17267 Discussions
problems with wrapping files together
-- i solved the problem already --
Hello community!
Again I got problems in my actual project :(
I want to wrap my memory (created with the megawizard) to my main project code. I already did this a few times and never had problems but this time I get the following error message during the compilation:
error (10482): vhdl error at microprocessor.vhd(80): object "memory" is used but not declared
my code to wrap the two files is following:
begin Edit: My problem was that I forgot to rename the component part of my memory. Sorry for this post uut: memory.vhd port map( data => data_in, clock => actualclock, address => memory_address_register, wren => memory_write, q => data_out );
Can anybody give me a hint how to solve this problem? Thanks in advance ;)
Best, orPoG
