17254 Discussions
wait for [variable] ns - Wait statement for a variable time possible?
Hello Community,
I got a problem with my current coding task: I want to create a small microprocessor in VHDL to work with assembly language via my mif-file. One of my tasks should be a wait statement.
The problem: it should be variable in time. I want to be able to wait as long as the number in my loaded memory is.
This code I tried to implement but it didn't compile:
when execute_wait => wait for memory_data_register ns; state <= fetch;
In this example my memory_data_register is the content which is read from my memory. It's type is unsigned.
I'd be perfect, if somebody can help me ;)
Best,
orPoG
Wait statements are only for simulation and indeed not synthesizable. You'll have to write a timer for this purpose.
Hello PietervanderStar,
thanks for your hint!
I've now solved the problem this way:
-- wait state process begin wait until clk_50MHZ'event and clk_50MHZ = '1'; if count_1KHZ /= 24999 then count_1KHZ <= count_1KHZ + 1; else count_1KHZ <= 0; clk_1KHZ <= not clk_1KHZ; end if; end process; process (clk_1KHZ) begin if (clk_choice = '0') then if rising_edge(clk_1KHZ) then if (count_individual_timer < timer_time) then count_individual_timer <= count_individual_timer + 1; individual_timer_EN <= '0'; else individual_timer_EN <= '1'; count_individual_timer <= 0; end if; end if; else individual_timer_EN <= '1'; end if; end process;
