17264 Discussions
qcrypt:test.rbf:8068: unexpected end-of-file
Steve-Mowbray-ENL
New Contributor II
Hi
When running Qcrypt on my working RBF configuration file I get the following result:
C:\Users\steve>D:/intelFPGA/21.1/quartus/bin64/qcrypt --encrypt --keyfile=keyfile.key --keyname=key1 --keystore=otp test.rbf test_qcrypt.rbf
Intel qcrypt 1.5 built at 12:02:50 on Aug 15 2017
Copyright (C) 2015-2017 Intel Corporation. All Rights Reserved.
Any clues as to what could be wrong would be appreciated - I am confused as the unencrypted  RBF file works fine with passive serial configuration..
Steve
Steve-Mowbray-ENL
New Contributor II
Sorted -- according to AN-556:
"Encryption and compression cannot be used simultaneously in 20 nm FPGAs."
Assignments->Settings->"Device and Pin Options..."->Configuration->"Generate compressed bitstreams" seems to be checked by default -- unchecked and the rebuilt RBF gets encrypted correctly by "Qcrypt" tool (at double the size...).
Steve-Mowbray-ENL
New Contributor II
