17268 Discussions
quartus 23.4 platform designer always failed to open.
Rainwang
New Contributor II
Tool version: Quartus prime pro 23.4, OS: Windows 10 22H2.
every time when i try to open the platform designer, it always fail several times.
sstrell
I'd try an uninstall and reinstall of Quartus.  Could be a bad installation.
ShengN_Intel
Do you have any further update or concern?
Sheng
Rainwang
New Contributor II
do you mean i need to try to un-install the quartus then re-install it?
ShengN_Intel
Yes, probably a bad installation.
Sheng
Rainwang
New Contributor II
my first installation is from the individual files and the 2nd I changed it to the multiple download, it seems the issue is still there......
There is a probability of failure every time when the platform designer is opened.
Rainwang
New Contributor II
there is always a failure probability when the platform designer is opened.
ShengN_Intel
Done tested on my platform without any problem check attached screenshot. Do you have any firewall, anti-virus or private wifi on?
ShengN_Intel
Any further update or concern? Does the problem being resolved by turning off firewall, anti-virus or private wifi if any?
Sheng
Rainwang
New Contributor II
hi, sheng,
No more update for this because i can't turn off the firewall. and pls close this case i will workaroud the issue by openning the platform designer several times when i use it.
thanks.
