17255 Discussions
quartus 7.2 cannot launch the modelsim-altera 6.1g
hi: guys
i use the quartus 7.2 web edition and modelsim altera6.1g to simulate next program
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity fpdiv is
port (
DIVz: out STD_LOGIC;
A: in STD_LOGIC_VECTOR (7 downto 0):="11111111";
B: in STD_LOGIC_VECTOR (7 downto 0):="00000010";
data_out: out STD_LOGIC_VECTOR (7 downto 0)
end fpdiv;
architecture fpdiv_arch of fpdiv is
signal REMAINDERS0 : STD_LOGIC_VECTOR (5 downto 0);
signal REMAINDERS1 : STD_LOGIC_VECTOR (5 downto 0);
signal REMAINDERS2 : STD_LOGIC_VECTOR (5 downto 0);
signal REMAINDERS3 : STD_LOGIC_VECTOR (5 downto 0);
signal DIVISORS0 : STD_LOGIC_VECTOR (5 downto 0);
signal DIVISORS1 : STD_LOGIC_VECTOR (5 downto 0);
signal DIVISORS2 : STD_LOGIC_VECTOR (5 downto 0);
signal DIVISORS3 : STD_LOGIC_VECTOR (5 downto 0);
signal Q_TEMP : STD_LOGIC_VECTOR (7 downto 0);
signal Z0 : STD_LOGIC_VECTOR (2 downto 0);
signal Z1 : STD_LOGIC_VECTOR (2 downto 0);
signal ZERO : STD_LOGIC;
begin
Z0 <= (others => '0');
Z1 <= (others => '0');
DIVISORS0 <= Z0 & B(2 downto 0);
REMAINDERS3 <= Z1 & A(2 downto 0);
DIVISORS1 <= DIVISORS0(4 downto 0) & '0';
DIVISORS2 <= DIVISORS1(4 downto 0) & '0';
DIVISORS3 <= DIVISORS2(4 downto 0) & '0';
Q_TEMP(0) <= '1' when (REMAINDERS1 >= DIVISORS0) else '0';
Q_TEMP(1) <= '1' when (REMAINDERS2 >= DIVISORS1) else '0';
Q_TEMP(2) <= '1' when (REMAINDERS3 >= DIVISORS2) else '0';
Q_TEMP(3) <= '1' when (REMAINDERS1 >= DIVISORS0) else '0';
Q_TEMP(4) <= '1' when (REMAINDERS2 >= DIVISORS1) else '0';
Q_TEMP(5) <= '1' when (REMAINDERS3 >= DIVISORS2) else '0';
Q_TEMP(6) <= '1' when (REMAINDERS2 >= DIVISORS1) else '0';
Q_TEMP(7) <= A(7) xor B(7);
REMAINDERS2 <= REMAINDERS3 - DIVISORS2 when Q_TEMP(2) = '1' else REMAINDERS3;
REMAINDERS1 <= REMAINDERS2 - DIVISORS1 when Q_TEMP(1) = '1' else REMAINDERS2;
REMAINDERS0 <= REMAINDERS1 - DIVISORS0 when Q_TEMP(0) = '1' else REMAINDERS1;
ZERO <= '1' when B(6 downto 0) = Z1 else '0';
DIVz <= '1' when ZERO = '1' else '0';
data_out <= (others => '0') when ZERO = '1' else Q_TEMP;
end fpdiv_arch;
the compile is success , when i use modelsim-altera to run EDA RTL simualtion i get next problem.
Info: Quartus(args): --rtl_sim fpdiv fpdiv
Info: Start Nativelink Simulation process
Info: NativeLink has detected VHDL design -- VHDL simulation models will be used
Info: Starting NativeLink simulation with ModelSim-Altera software
Error: Can't launch the ModelSim-Altera software -- the path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path.
Error: You can specify the path in the EDA Tool Options page of the Options dialog box or using the Tcl command set_user_option.
Error: NativeLink simulation flow was NOT successful
Info: For messages from NativeLink scripts, check the file C:/altera/72/quartus/fpdiv_nativelink_simulation.rpt
i already installation modelsim-altera and run is ok.
i set the setting in quartus 7.2 is following,the test bench is generation from quartus
testbench name: fpdiv.vht
top level model in test bench : fpdiv_vhd_tst
design instance name in test bench :TB
i set the path in environment variance point to the modelsim-altera
why i have this problem please tell me , i am a new coming.
thanks
Goto Tools->Options. Under EDA Tools Option (General), set your modelsim-altera path (e.g. C:\altera\72\modelsim_ae\win32aloem). Hope it helps.
please
modelsim v 6.1 is installed but not started when i double click on its icon
quartus 7.2 running is ok but i need to work with modelsim(6.1)and quartus (7.2) together and i have window xp also i download a licesing shared the both, i tree the following approch but it was not ok.
- Right click on My Computer icon, click properties
- Select Advanced tab and click on the Environment Variables button (right above OK button)
- in the "User Variables for user_name" section, click new
- Type in LM_LICENSE_FILE in the Variable Name section
- Type in the path (where your license file is located, e.g., c:\altera\license.dat) in the Variable Value section
- Click OK
- Close all the remaining windows by clicking OK in each of them
please help me
