17268 Discussions
quartus always crashes and gives the error
Whenever i run a compilation after the compilation quartus gives the error and stops working
Try re-installing the software. Are you tied to 12.1? I'd recommend using something newer, depending on your chosen target device(s).
Cheers,
Alex
yes i want to use a version which supports stratix-2 family
Sometimes the easiest way to get around a conflict between Quartus and whatever other software you might have installed is to install Quartus in a virtual machine.
That specific error you are getting related to MSVCRT libraries might end up being overly complicated to get around.
