17268 Discussions
quartus_cdb 17.1.0 crashes while generating vqm file
Hi All,
quartus_cdb crashes while generating vqm file. Please let me know if there is any solution
I am synthesizing simple adder as follows
module saxo_light_Add_24Ux24U_24U_4 (
in2,
in1,
out1
input [7:0] in2;
input [7:0] in1;
output [7:0] out1;
assign out1 = in2 + in1;
endmodule
The tcl command is as follows:
load_package flow
load_package report
load_package sdc
set module "saxo_light_Add_24Ux24U_24U_4"
set num 2
set family "StratixV"
proc syn { module family verilogInput} {
set proj [project_new -overwrite ./$module]
set_global_assignment -name FAMILY $family
set_global_assignment -name DEVICE Auto
set_global_assignment -name VERILOG_FILE saxo_light_Add_24Ux24U_24U_4.input.v
set_instance_assignment -name VIRTUAL_PIN ON -to in*
set_instance_assignment -name VIRTUAL_PIN ON -to out*
set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
execute_module -tool map
execute_module -tool fit
execute_module -tool cdb -args "--vqm=${module}.vqm"
syn $module $family $module
quartus_cdb crashes resulting with following info.
Info: *******************************************************************
Info: Running Quartus Prime Compiler Database Interface
Info: Version 17.1.0 Build 590 10/25/2017
Info: Processing started: Fri May 11 02:20:43 2018
Info: Command: quartus_cdb saxo_light_Add_24Ux24U_24U_4 -c saxo_light_Add_24Ux24U_24U_4 --vqm=saxo_light_Add_24Ux24U_24U_4.vqm
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Info (203002): Generated Verilog Quartus Mapping File using post-fit netlist
*** Fatal Error: Segment Violation at (nil)
Module: quartus_cdb
Stack Trace:
0xbbd90: DEV_DEVICE::get_pad_info() const (ddb_dev)
End-trace
