17252 Discussions
quartus compiling troubles
I am using win Xp pro;
When I run quartus compilation after modify a desing, it seems to compile correctly but it doen't seems to be able to create a new .sof file.
in the propject folder, i find only the pervious version of the *.sof file.
could anyone help me?
--- Quote Start ---
--- Quote End ---
which Device and Quartus Version did you use ?
Kind regards
GPK
Hi,thanks for your help.
I am using quartus2 9.1 web edition, no SP.
--- Quote Start ---
--- Quote End ---
Which device did you use ? Did you use some special IP blocks ? When you have an old sof-file, there must be an older successfull Quartus run. Is the run also done with a Web edition ?
Kind regards
GPK
I am using VIP cores, the device I qould like to configure is a cyclone2.
Yes, there are old sof-file, on the first compilation I get correct results.
The previous run is also done with a quartus2 web edition.
--- Quote Start ---
--- Quote End ---
what did you change after your first compilation ?
Kind regards
GPK
Someone (sys admin) just set up and configured a Sophos Antivirus.
I'tried to uninstall and reinstall the quartus, but still the same problem.
Maybe I didin't search the registry.
--- Quote Start ---
--- Quote End ---
look into the warning messsages. Any indication what goes wrong ?
Kind regards
GPK
Well, It was like the pogram hadn't write permissions, or any sectors oh the hard drive where damaged.
I formatted my hard drive and reinstalled quartus and windows, it seems to work all properly now.
