17252 Discusiones
quartus_jli device verify failure on USB 3.0
Colaborador Distinguido II
1.994 Vistas
Hi all,
# # Description
I'm having a verify failure when programming Cyclone IV with quartus_jli only when running on USB 3.0.
When I use the same computer with its USB 2.0 I don't have this issue.
Output:
Info: Command: quartus_jli -c 1 -a program ./firmware/BrainsightNIRS.jam
Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed!
Device# 1 is EPCS64
erasing ASC device(s) in sector mode...
programming ASC device(s) in sector mode...
CRC verify ASC device(s) in sector mode...
Device verify failure
Exit code = 11... Device verify failure
Error: Quartus Prime Jam Tools was unsuccessful. 0 errors, 0 warnings
Error: Peak virtual memory: 189 megabytes
Error: Processing ended: Fri Apr 21 11:39:21 2017
Error: Elapsed time: 00:01:35
Error: Total CPU time (on all processors): 00:00:19
# # Environment
* Ubuntu 16.04
* Quartus Altera Lite 16.0
* USB 3.0 (Computer) Connected to FX2 USB chip connected to FPGA Cylone IV
Had anyone had a similar problem?
0 kudos
0 Respuestas
Responder
