quartus_jli.exe error
IoanFlorucza
In our Automated Test System we are using the quartus_jli.exe cli application and the Altera Blaster download cable to program the the FPGA and flash and DSP of the board:
We are using a *.jam file to program the board.
quartus_jli.exe -aprogram -c1 Beta2_00wEcodST.jam
But we have the the following error of the console:
Device #1 is EPCS128
Expect device #1 to have 0 ASC devices of Unrecognized device
Exit code = 6... Unrecognized device
Error: Quartus Prime Jam Tools was unsuccessful. 0 errors, 0 warnings
Error: Peak virtual memory: 4302 megabytes
Error: Processing ended: Tue Jun 08 16:16:45 2021
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:00
I mention that if I use the Quartus Prime Programmer GUI application, and using the same setup / configuration I abled to program the board successfully:
Info (210117): Created JAM or JBC file for the specified chain:
Device 1 (EP3C40; C:/1/output_file.jic)
Device 2 (TMS320C6748; <bypass>)
Info (209060): Started Programmer operation at Tue Jun 08 16:13:08 2021
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F40DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209018): Device 1 silicon ID is 0x18
Info (209044): Erasing ASP configuration device(s)
Info (209023): Programming device(s)
Info (209021): Performing CRC verification on device(s)
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Tue Jun 08 16:13:27 2021
Info (209060): Started Programmer operation at Tue Jun 08 16:17:37 2021
Info (209061): Ended Programmer operation at Tue Jun 08 16:17:58 2021
But when from the GUi application the JAM file is created, and then using the quartus_jli.exe CLI application i have these errors with the same JAM file.
So which with the CLI app i get this error and with the GUI app no errors:
Please advice.
JohnT_Intel
Before you program the flash, you need to configure the FPGA.
In order to program the FPGA, you need to performed "quartus_jli.exe -aconfigure -c1 Beta2_00wEcodST.jam" then only you performed "quartus_jli.exe -aprogram -c1 Beta2_00wEcodST.jam"
You may refer to the AN425 (https://www.intel.com/content/www/us/en/programmable/documentation/sam1403762199737.html). Below is the Note that I copy from the document
Note: To program serial configuration devices with the Jam STAPL Player, you must first configure the FPGA with the Serial FlashLoader image. The following commands are required:
jam -aconfigure <filename>.jam
jam -aprogram <filename>.jam
