quartus on linux
Colaborador honorário II
1.593 Visualizações
hi im new in fpga and try to install Qartus II 9.1 sp2 on fedora 25 , installation done but when i try to run quartus with this command " /opt/altera9.1sp2/quartus/bin/quartus --64"
i facing this message "quartus: error while loading shared libraries: libSM.so.6: cannot open shared object file: No such file or directory"
in other side i install libSM.so.6 librarie
ls |grep libSM.so.6
libSM.so.6
libSM.so.6.0.1
please help me to solved my problem
2 Respostas
647 Visualizações
Not sure what version on linux you are using, but for CentOS/Redhat I need to install the libSM-dev rpm
login1(13)# find /usr -name libSM.so
/usr/lib64/libSM.so
login1(14)# rpm -qf /usr/lib64/libSM.so
libSM-devel-1.2.2-2.el7.x86_64
login(15)#
647 Visualizações
thank you by reinstall and update to 13.1 my problem solved
Responder
