17249 Discussions
quartus system console font too small, windows 11, monitors 2496 / 1664
drjohnsmith
What is up with Quartus , using lates, on W11 ,
see in  screen shot atatched,
     the text in the background, is a web browser,  quiet happy with windows resolution, font is very readable, whilst Quartus , seems to be hard fixed for a resolution of around 1920 by 1220
Is there a setting one has to fiddle with to make the console readable ?
  or do I have to drop back 20 to a lower resolution monitor ?
SyafieqS
Let me know if there is any update at your end.
sstrell
I think there's an option to adjust font size in the Tools or View menu there.
drjohnsmith
May be its too small to read, but I can't see option to change font in the tool ,
SyafieqS
Can you check on Tool --> Option --> Message (font).
Try to change the size, let me know if that is feasible.
drjohnsmith
Thank you
negative improvement,
I now have massive and small fonts on different parts of the GUI
   the setting only seems to change the message window .
drjohnsmith
One step forward,
under tools options in the IP parameter editor , I found this ,
so It seems I have to set font size in each tool. depending if Im working on the big screen or the laptop screen !
Uhm,  unusual..
SyafieqS
Understood.
Does that work for you? Changing the font as you mentioned.
I am not able to see the issue when using W11 with Quartus on second monitor.
SyafieqS
drjohnsmith
Morning,
   apologies, had problems with this Intel TFA to get into the forums,
Yes has success,
   but as mentioned, if I change monitor resolution , end up with fonts all to big / small again.
  where as program such as say "word" seem to have some method of knowing the screen resolution such that say a size 10 font is readable on both the high resolution screen and th elow resolution one.
Don't know how it works, Im a hardware person,
    example.
  I have here a 3840 by 2160 screen ,
     my laptop has a 2496 by 1664 screen , but is much smaller, so Im guessing the dots per inch is around the same, or what ever the number is .
Seems in the Intel s/w , one has to go into each program and change the fonts to make it readable on each screen,
     where as other programs , the fonts are readable on both,
  don't know why this is is
    having looked on line, seems a particular Intel thing
      but
  we are where we are,
     thank you
SyafieqS
Does this issue appear to other monitor as well?
If that's the case, you have to manually change the font as mentioned as workaround.
drjohnsmith
Yes @SyafieqS
It seems general "feature" of the Intel Quartus software, that unlike other windows programs, For each resolution monitor, one has to change the font size in the program .
As I'm moving between laptop, multi monitor and large monitors it is certainly noticeable.
Im not a sw engineer but I wonder why its just the intel code ?
  I've not been using Altera / Intel code for about a decade, been on other fpga families, and this font bug is very noticable Intel related.
Thank you
MauricioM
Hi John!
I had the same Issue, I solved it going to the install folder, in my case: "intelFPGA_pro\22.2\syscon\bin"
Next doing the instructions on the following link for the file "system-console.exe":
https://www.thewindowsclub.com/how-to-change-scaling-for-specific-apps-in-windows-11?expand_article=1
I used System (Enhanced) on the last options, after that you can open the system-console from quartus or what I'm going to do is also create a shortcut from here so it's a little faster than opening quartus and then system console.
Hope this helps.
Mauricio
SyafieqS
Hi John,
Massive thanks for the update. Ill keep this as a feedback and reevaluate the issue. Since the WA is feasible I will close this ticket.
SyafieqS
I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
