17252 Discussions
question regarding random number generator
hii..
i would like to ask if there is any library that have a function to generate numbers randomly within certain range..???
i wanna make a component that takes an input once add to its value 15 and subtract from it 15 and gives output within this range randomly
i.e --> output= rand[input+15, input-15]
i've no problem with the design except of the part of random value generation
i did some work arround to do so that i'm not satisfied with..
here is what i did --> xoring 2 bits putting the result in another place..
any idea how can i do this..
all your helps highly appreciated..
thanks,
Niveen..
Questions:
1. Should this block be synthesisable?
2. How "random" does it need to be?
I ask these questions because:
1. VHDL has a random number generator, but it is not synthesisable and only meant for testbenches
2. Have you looked into a LFSR? http://en.wikipedia.org/wiki/lfs with this you can create a pseudo random sequence. This would be the easiest logic solution. I have heard of others before but they often involve rlocs and require good knowledge on oscilators. One solution (i havent done it, but had it described) is to route a clock though some logic as far apart as possible. Then sample the clock at a given rate, to try and give a random bit (it was described to me a long time ago, so I may have some details wrong).
--- Quote Start ---
Questions:
--- Quote End ---
no just testing
--- Quote Start ---
Questions:
--- Quote End ---
i want to generate 36 output values with only 1 input
--- Quote Start ---
Questions:
--- Quote End ---
would plz tell me about it, and if it take range or not??
--- Quote Start ---
Questions:
--- Quote End ---
the work arround i did was similar to LFSR..
execuse me, i couldn't get the rest of this..
thanks,
Niveen
Per Tricky's comments, if an LFSR is sufficient, there is a tutorial and code here:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip
You would need to decide whether you want uniform or Gaussian(-like) noise, and then just scale it to the numeric range you describe above.
Cheers,
Dave
There's a synthesizable random number generator using an inverter chain in the Altera cookbook: http://www.altera.com/literature/manual/stx_cookbook.pdf
See chapter 14
Thanks alot Dave for the tutorial.. :)
whenever i try to post any "reply with quote" it dissapear once i click "post".. any idea why does this happen
thanks,
Niveen..
Thanks alot jederrick for the cookbook link.. :)
--- Quote Start ---
--- Quote End ---
Works fine for me - WinXP + Firefox.
Cheers,
Dave
