17255 Discussions
"is not declared under this prefix"
SFalk3
Hello all,
I'm getting the following errors during Analysis and Synthesis and I can't find much about them using Google.
Error (10733): Verilog HDL error at spi_shapes_to_video.sv(67): color is not declared under this prefix Error (10733): Verilog HDL error at spi_shapes_to_video.sv(86): y is not declared under this prefix
If it's relevant, the file that is being referred to is part of a generated component under Platform Designer.
Here is the source file spi_shapes_to_video.sv
module spi_shapes_to_video ( input wire spi_clk_clk, // spi_clk.clk input wire video_clk_clk, // video_clk.clk input wire spi_rst_reset, // spi_rst.reset input wire video_rst_reset, // video_rst.reset input wire [7:0] spi_sink_data, // spi_sink.data input wire spi_sink_valid, // .valid input wire video_source_ready, // .ready output logic spi_sink_ready, // .ready output logic [15:0] video_source_data, // video_source.data output logic video_source_startofpacket, // .startofpacket output logic video_source_endofpacket, // .endofpacket output logic video_source_valid // .valid );   localparam NUM_LINES_WIDTH = 10; localparam NUM_LINES = 1 << NUM_LINES_WIDTH; localparam SCREEN_WIDTH = 640; localparam SCREEN_HEIGHT = 480; localparam COLOR_BG = 16'b0;   typedef enum { STATE_PRE_INPUT, STATE_INPUT, STATE_PRE_OUTPUT, STATE_OUTPUT } state_t;   typedef struct packed { logic [3:0] alpha; logic [3:0] r; logic [3:0] g; logic [3:0] b; } color_t;   typedef struct packed { logic [9:0] x; logic [8:0] y; } point_t;   typedef struct packed { logic [1:0] align_bits; point_t start_point; point_t end_point; color_t color; } line_t;   function line_has_point ( input point_t point, input line_t line );   line_has_point = (point.y - line.start_point.y) * (line.end_point.x - line.start_point.x) == (point.x - line.start_point.x) * (line.end_point.y - line.start_point.y); endfunction   function color_t get_color( input point_t point ); integer i; color_t out; begin out = COLOR_BG; for (i = 0; i < NUM_LINES; i++) begin if (line_has_point(point, lines[i])) out = lines[i].color; end get_color = out; end endfunction   function state_t get_next_state( input state_t state ); case(state) STATE_PRE_INPUT: get_next_state = STATE_INPUT; STATE_INPUT: if (lines_index == NUM_LINES) get_next_state = STATE_PRE_OUTPUT; else get_next_state = STATE_INPUT; STATE_PRE_OUTPUT: get_next_state = STATE_OUTPUT; STATE_OUTPUT: if (current_point.y == SCREEN_HEIGHT) get_next_state = STATE_PRE_INPUT; else get_next_state = STATE_OUTPUT; default: get_next_state = STATE_PRE_INPUT; endcase endfunction   state_t state; logic [1:0] video_clk_vals; line_t [NUM_LINES-1:0] lines /* synthesis ramstyle = "M9K" */;   logic [NUM_LINES_WIDTH:0] lines_index; logic [2:0] line_byte_count;   point_t current_point;   always @(posedge spi_clk_clk) begin if (~spi_rst_reset) begin lines = 0; lines_index = 0; line_byte_count = 0; video_clk_vals = 2'b0; state = STATE_PRE_INPUT; current_point = 0;   spi_sink_ready = 1'b0; video_source_valid = 1'b0; video_source_data = 16'b0; video_source_startofpacket = 1'b0; video_source_endofpacket = 1'b0; end else begin video_clk_vals = {video_clk_vals[0], video_clk_clk}; state = get_next_state(state); case(state) STATE_PRE_INPUT: begin lines_index = 0; end STATE_INPUT: begin spi_sink_ready = 1'b1; video_source_valid = 1'b0; if (spi_sink_valid) begin lines[lines_index] = {lines[lines_index][47:0], spi_sink_data}; line_byte_count += 1; end if (line_byte_count == 7) begin lines_index += 1; line_byte_count = 0; end end STATE_PRE_OUTPUT: begin spi_sink_ready = 1'b0; current_point = 0; end STATE_OUTPUT: begin // negedge of video clock if (video_clk_vals == 2'b10) begin if (video_source_ready) begin video_source_valid = 1; video_source_data = get_color(current_point);   video_source_startofpacket = current_point == 0; video_source_endofpacket = current_point.x == SCREEN_WIDTH - 1 && current_point.y == SCREEN_HEIGHT - 1;   current_point.x += 1; if (current_point.x == SCREEN_WIDTH) begin current_point.x = 0; current_point.y += 1; end end else begin video_source_valid = 0; end end end endcase end end endmodule
 Thanks for any help with this... I have no idea what the issue is.
RichardTanSY_Altera
The error code meant to fix the problem identified by the message text.
Could you share your project so I can further check on this?
SFalk3
Hello, thanks for your response. I've attached the project to this message. I am using Quartus Prime Lite version 18.1.
SFalk3
Okay I fixed the issue by not referencing variables outside the scope of the function. So I passed in lines as an argument to get_color and current_point as an argument to get_next_state. Still, I wonder why this is necessary. I thought that I should be able to access module variables from within a module function.
RichardTanSY_Altera
I found out if I relocate these two lines. (see attached) It seems to pass the error.
