17255 Discussions
"j" is not a constant in verilog for loop addition
I am trying to make a simple for loop to add up a parameterizable count of numbers, all in the same clock cycle( I am aware that this may not fit in a single cycle, I may split it up later to more cycles if timing issues arise.). What I am trying to do in essence is(for 3 numbers):
always@(posedge clk) out=in+in+in;
I am getting the error: "j is not a constant".
I am sure there is a method to do this, am I trying to do this in a wrong way?
My full code is:
module mymodule# ( parameter maxIter = 9, parameter bitCount = 16 )( input wire clk, input wire in, output reg out ); initial begin out=0; end integer j; always@(posedge clk)begin for (j=0; j<maxIter; j=j+1) begin // I have tried this // out= out + in; // Then on a forum I found this out= out + in; // Neither works end end endmodule
You want
out= out + in[bitCount*j +: 16];
rozatib
Verilog specifies that if you are taking a slice, one of the indices must be a constant.
Thank you very much, problem solved.
