ram with byte enable
Is it possible to infer a block ram with byte enable in VHDL using Quartus II? I'm trying to infer a 1024x32 single port ram with 4 enable bits, but after synthesis, Quartus II infers 4 independient ram blocks of 1024x8, one for each enable bit. I don't want to instantiate 'cause I need to implement my project in a Xilinx FPGA too.
Nick
Sorry no way to do that.
You need to use two VHDL architecures, one for altera direct instantiation and one for Xilinx direct instantiation.
I have experience with both and this is the only way I think it will work.
Inferrence of byte enables is not supported by Altera nor Xilinx
Thanks! I'll do that.
