real in vhdl
hi all
i want to ask a question and i don't know if it possible in vhdl or how to make it.
if i have an eqution such as
x= m(a)+a*max(a)+b*sd_d(a)
and the values of a and b is as
a=1
b=1.5
a=1
b=1.75
a=1.5
b=0
and i want to substitue the values of a,b every time and check the x value with comparator
how i make it in vhdl.any idea please
The values of a and b that you give can be represented using "fractional integer format". Assuming the values of a and b can be signed values, you can use a 4-bit integer in Q1.2 format. This format can represent the following values;
Binary Q1.2 Value ------ ---------- 01.11 1.75 01.10 1.50 01.01 1.25 01.00 1.00 00.11 0.75 00.10 0.50 00.01 0.25 00.00 0.00 11.11 -0.25 11.10 -0.50 11.01 -0.75 11.00 -1.00 10.11 -1.25 10.10 -1.50 10.01 -1.75 10.00 -2.00
You can use these numbers, along with the knowledge that a multiplication of two Q1.2 numbers yields a Q3.4 value (eg., -2.00 x -2.00 = +4.00 = 0100.0000b) and addition results in a Q3.2 number, to determine the bit-growth in your equation. The resulting value of x can either be used directly, or convergent rounded to whatever bit-width you need for your design.
If none of this makes any sense, read these notes ...
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104paper_hawkins.pdf
Cheers,
Dave
you mean ichould convert this constant values first to binary and then to integer to multiply with integer signal
--- Quote Start ---
you mean i could convert this constant values first to binary and then to integer to multiply with integer signal
--- Quote End ---
Yes. There is no "rule" that says your constants must use floating-point. If fixed-point numbers represent the fractional part with the same precision as floating-point, then you will get the same answer. The math is the same.
Cheers,
Dave
