17259 Discussions
VHDL 8 bits comparator using 2 * 4 bits comaparator
Hay everyone ,
i am trying to simulate a 8 bits comparator using 2 * 4 bits comparators here's my code .... it's compile --> no errors
but i have 3 red lignes in the wave
this is the 4bits comparator (with 3 outputs ega , inf and sup)
Library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity Comp_4Bits is port( A : in std_logic_vector (3 downto 0); B : in std_logic_vector (3 downto 0); SUP : out std_logic; iNF : out std_logic; EGA : out std_logic); end Comp_4Bits ; Architecture RTL of Comp_4Bits is begin process(A, B ) begin if (A> B then Sup <='1' ; Inf <='0' ; Ega <='0' ; Elsif (A< Bthen Inf <='1' ; Sup <='0' ; ega <='0' ; elsif (A= B then Ega <='1' ; sup <='0' ; inf <='0' ; end if ; end process ; end RTL;
and here is the code of 8 bits comparator
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std ; entity compa_8bits is port( A:in std_logic_vector(7 downto 0); B:in std_logic_vector(7 downto 0); ega : out std_logic ; sup : out std_logic; inf : out std_logic ); end compa_8bits; architecture RTL of compa_8bits is signal sup1 , sup2 , inf1 , inf2 , ega1 , ega2 , sig1 , sig2:std_logic; component Comp_4Bits is port( A:IN std_logic_vector(3 downto 0); B:IN std_logic_vector(3 downto 0); ega : out std_logic; sup : out std_logic; inf : out std_logic); end component ; begin u1:Comp_4Bits port map ( A =>A(7 downto 4), B=>B(7 downto 4), ega=>ega1 , sup=>sup1, inf=>inf1 ); u2:Comp_4Bits port map ( A=>A(3 downto 0), B=>B(3 downto 0), ega=>ega2, sup=>sup2, inf=>inf2); inf <= inf1 or (ega1 and inf2); sup <= sup1 or (ega1 and sup2); ega <= ega1 and ega2; END RTL;
and finally the test bench
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std ; entity compa_8bits_tb is end compa_8bits_tb; architecture BHV of compa_8bits_tb is component compa_8bits is port( A:IN std_logic_vector(7 downto 0); B:IN std_logic_vector(7 downto 0); sup : out std_logic; ega : out std_logic; inf : out std_logic ); end component; signal A, B : std_logic_vector( 7 downto 0) ; signal ega, inf, sup: std_logic; begin Dut1: compa_8bits port map( A => A , B => B , ega=>ega , sup =>sup, inf=>inf ); process begin A<="11110000"; B<="01101111"; wait for 20 ns; A<="01110000"; B<="01110000"; wait for 30 ns; A<="10011111"; B<="01101010"; end process; end BHV;
thanks a lot =D
Once I fixed the syntax error in the first code, it worked just fine.
PS> In your testbench, do you realise the 3rd set of A and B values are not input because it loops back around to the start of the process again
