17260 Discussions
How to implement a code that uses floating-point?
Hello, How should I do to implement in VHDL, a code that calculates the following equation: u(k) = 622,5u(k-1) + 0,6279u(k-2) + 651,2e(k) + 0,000814e(k-1) - 651,2e(k-2). I am a beginner in VHDL and do not know how to work with floating point. I think it not possible to represent the coefficients ranging from 651.2 to 0.000814 with fixed point. After implementing the code, I want to synthesize the circuit. I am using the Quartus II 64-bit Version 10.1 (Build 153 11/29/2010 ). Below, the main questions:
1. What libraries should I use? How do I compile the libraries?
2. How should I declare in the code variable u(k) to get a real number as a result of the equation?
Ps. I don't want to use the Nios, and the code should be synthesizable.
Thanks for the space...
1. You will need to use the floating point IP cores. Have a read of the user guides: http://www.altera.co.uk/literature/ug/ug_altfp_mfug.pdf
2. It will be a std_logic_vector. THe IP cores do the work, you just wire them together.
No nios needed, a floating point calculation is perfectly usable. But expect the resource usage and latency to be quite large (probably >100 clk cycles of latency).
The IIR filter structure can be only implemented if the latency is smaller than the sample period. This might be a problem with float IP.
Generally I assume that a fixed point implementation will better serve the intended purpose.
Ok, thanks...I'm going to read the guide recommended.
--- Quote Start ---
--- Quote End ---
I think it not possible to represent the coefficients ranging from 651.2 to 0.000814 with fixed point. Unless I do the staggering numbers. Am I right?? Fixed point representation uses 32 bit, right??
fixed point representation uses as many bits as you require. The beauty of fixed point is that it is just an integer offset by 2^n, so you can use the multipliers on the FPGA and the latency is really small (is its just integer arithmatic).
Also, with a massive range of co-efficients, do you really need such small ones? will they really have much of an effect on the output?
--- Quote Start ---
--- Quote End ---
I really need the small values, because they are part of an equation of the controller. Sorry, but What you mean by that "with a massive range of co-efficients" ???
