17255 Discussions
sdc constraint Warning with altera_reserved_tck
I have a design using Timequest. Suggested by altera website(rd04282008_867), I write this
constraint in .sdc file: create_clock -period "100.000 ns" -name {altera_reserved_tck} {altera_reserved_tck}
After compiled the design, I received warnings below:
--- Quote Start ---
Warning: At least one of the filters had some problems and could not be matched.
        Warning: altera_reserved_tck could not be matched with a port.
    Warning: Ignored assignment: create_clock -name {altera_reserved_tck} -period 100.000 -waveform { 0.000 50.000 } [get_ports {altera_reserved_tck}]
        Warning: Argument <targets> is an empty collection
--- Quote End ---
Some info before these warnings:
Info: Starting physical synthesis optimizations for speed
    Info: Fitter is using the TimeQuest Timing Analyzer
    Info: Reading SDC File: 'Optimization.sdc'
I wonder whether I need to change some settings? Can anyone make suggestions? thx.
Does the clock show up in Report Unconstrained Paths?
Note that the JTAG clock now has a clock constraint embedded in it's RTL, so you generally don't have to do this anymore. I assume you're doing it to fix a problem, but not sure what the problem is.
I checked Report Unconstrained Paths, and I found out I made a foolish mistake.
As I changed the design, the node specified in signal tap became invalid. As a result, tck is not used in my design. After I fixed .stp file, the warning is solved.
Thanks for your advice
