hi
im new to vhdl programming. i have a component ------comp port map (a(I),S(I), k);---- in file 1 which is generated 8 times by generate statement and in file 2 sub1 (file 1) is instantiated 2 times ... i have to add select signal with 8 bits in top file (file 2 )...now i need to write a logic to select comp2 when select signal in top file is 00000001 to 00001000 i.e component 1 to 4 and 00010000 to 10000000 for 5 to 8....pls give a solution ... file 1:entity sub1 is (x:in std_logic y:in std_logic z:out std_logic); ------some other signals end entity architecture b of a is ---- ---- lines of code -,--- for I in 0 to 7 generate
accname: acc port map (a(I),S(I), k); cpuname: cpu port map (h(I),o(I), f); end architecture;
file 2: entity maintop is (l:in std_logic m:in std_logic n:out std_logic); ------some other signals end entity architecture toparc of maintop is comp1 : sub1 port map (x,y, z); comp2 : sub1 port map (x,y, z); end arc
? from your question it is unclear what strategy you try to use to acomplish problem.
Try simple multiplexor , change sub1 entity design Draw a port connectivity diagram that you await to clarify your question
