17255 Discussions
set_max_delay and set_min_delay is no sense for project compile
lambert_yu
Hi sir,
     I face one problem, and I have no idea for the set_max_delay and set_min_delay constrains, the problem as follows:
     I want to constrains the delay from the reg_q to the port_o, but I found there is no effect when I constrain the datapath, and the time report presents the delay is large the value that I set.
   The timing report as follows:
     the constrains as follows:
     set_min_delay  -from spi_master_wrap_u|spi_tx_u|tx_sck_o|q -through spi_master_wrap_u|sck_o~0|combout -to m_spi_ck_o~output|i 0.200
     set_max_delay  -from spi_master_wrap_u|spi_tx_u|tx_sck_o|q -through spi_master_wrap_u|sck_o~0|combout -to m_spi_ck_o~output|i 2.100
     Is there any problem for the constarins or it's not correct to use these constrains. Would someone will help me?
  Software:quartus II 13.1
  FPGA chip: Arria V AGXA7
Lambert
KhaiChein_Y_Intel
This might due to the value you set exceeds the limitation of the max/min delay value.
KhaiY
lambert_yu
Hi KhaiY
   I am  so happy for your response, but would you help me to know how can I estimate or find the limitation for the max/min delay value?
Lambert
KhaiChein_Y_Intel
It depends on the location of the source and destination. If you set min/max delay and you see the delay in the Timing Analyzer exceeds the value that you set, the value in the Timing Analyzer is min/max for the same source/destination location.
KhaiY
lambert_yu
Hi KhaiY,
   If so, I want to know, if the max/min value which I set is not satisfied by software, will it provide violation message? Now, it does not present this message in timing report, it's normal?
BR,
Lambert
KhaiChein_Y_Intel
Hi Lambert,
You are correct. This will not reported as warning or error message.
KhaiY
KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
KhaiY
