I am have installed Quartus STD 20.1 version, & continued using Evaluation.
While creating new project wizard for Cyclone5 5CSEBA6U23I7, after click on finish, software not responding. I have seen same issue in Quartus lite 20.1 & 19 version as well.
Question is : Do I am missing something after installation?
Thank You.
Hi Shintansh,
The issue is probably because you are saving you project files in Quartus installation path. By defaults the project location to C:\intelFPGA_lite\20.1 which is read-only. It should default to e.g. the Documents directory or require you to enter a path. In the new project wizard try to change to any new directory you want and create new project, it should be okay.
Cheers,
Syafieq
Hi Shintash,
Make sure you meet all the basic system and requirement for Cyclone V. Please refer to link below for details
https://fpgasoftware.intel.com/requirements/20.1/
Following are general methods what you should do:
1. Make sure your OS is up to date
2. Kill any heavy background running while using Quartus
4. Reinstall Quartus and relaunch
Hi Shintansh,
Cheers,
Syafieq
