signaltap compile error
The device is Cyclone IV E EP4CE115F29C8, before adding signaltap module, the whole project works fine from compile to generate sof file. but after I add the signaltap module, there are errors:
Error (12077): Node instance "\stp_non_zero_ram_gen:stp_buffer_ram" instantiated with unknown parameter "ecc_pipeline_stage_enabled"
Error (12077): Node instance "\stp_non_zero_ram_gen:stp_buffer_ram" instantiated with unknown parameter "stratixiv_m144k_allow_dual_clocks"
Error (12077): Node instance "\stp_non_zero_ram_gen:stp_buffer_ram" instantiated with unknown parameter "width_eccstatus"
Error (12154): Can't elaborate inferred hierarchy "sld_signaltap:auto_signaltap_0|sld_signaltap_impl:sld_signaltap_body|sld_signaltap_implb:sld_signaltap_body|altsyncram:\stp_non_zero_ram_gen:stp_buffer_ram"
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 4 errors, 480 warnings
Error: Peak virtual memory: 976 megabytes
Error: Processing ended: Mon Aug 24 13:43:39 2015
Error: Elapsed time: 00:01:48
Error: Total CPU time (on all processors): 00:02:00
Have no idea why this happen and how to fix it
Which Quartus II version are you using? Have you tried with different versions to see if still occur?
I am running into something similar. How did you fix this?
