17263 Discussions
signed input signal does not show "signed" in .vo
hi,everyone:
I edited a program about CORDIC,but I got a problem.
I declared some "signed input" in .v file. But after synthesizing,signed
input does not show "signed" in .vo file.That causes some warning
message such as"# RUNTIME: Warning: RUNTIME_0154 cycloneii_atoms.v
(6702): Replication multiplier is not positive: 0 "when I operate timing
simulation with Active HDL8.1. And the output signal values of timing
simulation are not the same as those of funtional simulation.
How can I solve this problem?
I use Quartus 7.2sp3,cyclone II EP2C35F672C6 and Active HDL8.1.
AND I listed .v and .vo file below:
1. Shift_adder_subtractor.v:
module Shift_adder_subtractor ( X ,Y ,i ,A ,B ,Sign_X_mul_Y ,u ,m,clk,rst,out_en);
input [4:0]i ;
wire [4:0]i ;
input signed[17:0] A ;
wire signed[17:0] A ;
input signed[17:0] B ;
wire signed[17:0] B ;
input signed [1:0]u ;
wire signed [1:0]u ;
input signed [1:0]m ;
wire signed [1:0]m ;
input clk ;
wire clk ;
input rst ;
wire rst ;
output out_en ;
reg out_en ;
output signed[17:0] X ;
reg signed[17:0] X ;
output signed[17:0] Y ;
reg [17:0] Y ;
output signed [1:0]Sign_X_mul_Y ;
reg signed [1:0]Sign_X_mul_Y ;
reg signed[17:0] A1;
reg signed[17:0] B1 ;
reg[2:0]state;
`define idle 0
`define shift_A_B 1
`define sel_sys_mode 2
`define add_subtract 3
`define out_X_Y 4
//}} End of automatically maintained section
// -- Enter your statements here -- //
always @(posedge clk or negedge rst)
begin
if(!rst)
begin
out_en<=1'b0;
A1<=18'sh0;
B1<=18'sh0;
Sign_X_mul_Y<=2'sb1;
X<=18'sh0;
Y<=18'sh0;
state<=`shift_A_B;
end
else
begin
//if(en==1'b1) state<=`shift_A_B;
//else state<=`idle;
case(state)
`idle:
begin
state<=`shift_A_B;
end
`shift_A_B:
begin
out_en<=1'b0;
A1<=A>>>i;
B1<=B>>>i;
state<=`sel_sys_mode;
end
`sel_sys_mode:
begin
A1<=u*A1;
B1<=m*u*B1;
state<=`add_subtract;
end
`add_subtract:
begin
A1<=A-B1;
B1<=A1+B;
state<=`out_X_Y;
end
`out_X_Y:
begin
Sign_X_mul_Y<={A1[17]|B1[17],1'b1};
X<=A1;
Y<=B1;
state<=`idle;
out_en<=1'b1;
end
endcase
end
end
endmodule
2.Shift_adder_subtractor .vo:
timescale 1 ps/ 1 ps
X,
Y,
i,
A,
B,
Sign_X_mul_Y,
u,
m,
clk,
rst,
out_en);
output [17:0] X;
output [17:0] Y;
input [4:0] i;
input [17:0] A;
input [17:0] B;
output [1:0] Sign_X_mul_Y;
input [1:0] u;
input [1:0] m;
input clk;
input rst;
output out_en;
