Today, I had a nios2 system. Time in debugging, are all normal. However, when load in de2 board, not the results of operation. I would like to ask why, and how to resolve them.Thanks!:)
Next is the test programme: # include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h" int main (void) __attribute__ ((weak, alias ("alt_main"))); int alt_main (void) { alt_u8 led = 0x2; alt_u8 dir = 0; volatile int i; while (1) { if (led & 0x81) { dir = (dir ^ 0x1); } if (dir) { led = led >> 1; } else { led = led << 1; } IOWR_ALTERA_AVALON_PIO_DATA(LEDG_BASE, led); i = 0; while (i<200000) i++; } return 0; }Link Copied
there may have some problem with your hardware,eg down load was not successfully executed.but the sorftware tell ok.or,the hardware description is not the right one to your programme.that are all i guess
Thanks!It's helpfull!
