17258 Discussions
Using nios2 system to let led display,but not success
Today, I had a nios2 system. Time in debugging, are all normal. However, when load in de2 board, not the results of operation. I would like to ask why, and how to resolve them.Thanks!:)
Next is the test programme:
# include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"
int main (void) __attribute__ ((weak, alias ("alt_main")));
int alt_main (void)
alt_u8 led = 0x2;
alt_u8 dir = 0;
volatile int i;
while (1)
if (led & 0x81)
dir = (dir ^ 0x1);
if (dir)
led = led >> 1;
else
led = led << 1;
IOWR_ALTERA_AVALON_PIO_DATA(LEDG_BASE, led);
i = 0;
while (i<200000)
i++;
return 0;
there may have some problem with your hardware,eg down load was not successfully executed.but the sorftware tell ok.or,the hardware description is not the right one to your programme.that are all i guess
Thanks!It's helpfull!
