im a newbie in quartus II.i tried to simulate the full adder in verilog hdl but it seems cant work!!when i tried to compile the files, there's no error but have a few warnings.
but when it comes for simulation...the msg appeared>> Error: Can't launch the Active-HDL software -- the path to the location of the executables for the Active-HDL software were not specified or the executables were not found at specified path. Error: You can specify the path in the EDA Tool Options page of the Options dialog box or using the Tcl command set_user_option. Error: NativeLink Simulation failed Am i did the wrong files source code or the way i setting the eda simulation tools is not correct??pls help me... this is my full adder file module fulladder (a,b,carry_in,sum,carry_out); input a,b; input carry_in; output [1:0] sum; output carry_out; half_adder H1 (carry, sum[0], a, b); half_adder H2 (carry_out, sum[1], carry, carry_in); endmodule module half_adder(carry, sum, a, b); input a; input b; output carry; output sum; xor X1 (sum, a, b); and A1 (carry, a, b); endmoduleLink Copied
Go to tools -> options. Under General, EDA Tool Options. Set the executable path for Active-HDL simulator (e.g. C:\Program Files\Aldec\Active-HDL 7.2\BIN). Then later you can launch the simulator using native-link (i.e. Tools->EDA Simulation Tools -> Run ...)
u mean set the executable path for the same file?i tried to do like what u said but it doesnt work
