simulation with modelsim
hi every body.i wrote a code for a common bus with 4 registers(8 bit )and asimple alu that ableto do some logical and arithmetic operation.
registers r0,r1 and r3 inputs directly are connected to bus but r2 input is connected directly to alu output.all off four registers output via selects line
and muxs are connected to bus.i wrote testbench for my code but i dont know why the registers in and out and my bus dont initialized.please help me about the
reasons.my code and testbench are:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
-- instead off two past sentenses you are authorized for using use ieee.numeric_std.all;
entity comm_bus is
port(r0_in,r1_in,r3_in:inout std_logic_vector(0 to 7);
--r2_in is not needed because we use from alu_out
r0_out,r1_out,r2_out,r3_out:inout std_logic_vector(0 to 7);
-- registers input & output must be identified inout and you dont have any way
r0_clr,r1_clr,r2_clr,r3_clr:in std_logic;
clk:in std_logic;
r0_ld,r1_ld,r2_ld,r3_ld:in std_logic;
opr:in std_logic_vector(2 downto 0);
sel:in std_logic_vector(1 downto 0);
bus_8bit:inout std_logic_vector(0 to 7));
end comm_bus;
-- for alu operation & selection mechanism we wana use from interface signals-----------
architecture behavioral of comm_bus is
signal alu_arm1,alu_arm2,alu_out:std_logic_vector(0 to 7);
--signal opr:std_logic_vector(2 downto 0);
--signal sel:std_logic_vector(1 downto 0);
begin
process(clk)
begin
if (rising_edge(clk)) then
if (r0_clr='0') then
r0_out<=(others=>'0');
end if;
if (r1_clr='0') then
r1_out<=(others=>'0');
end if;
if (r2_clr='0') then
r2_out<=(others=>'0');
end if;
if (r3_clr='0') then
r3_out<=(others=>'0');
end if;
end if;
end process;
process(clk)
begin
if (r0_ld='1') then
r0_out<=r0_in;
end if;
if (r1_ld='1') then
r1_out<=r1_in;
end if;
if (r2_ld='1') then
r2_out<=alu_out;
--alu_out directly transfer to r2_out
end if;
if (r3_ld='1') then
r3_out<=r3_in;
end if;
end if;
end process;
r0_in<=bus_8bit;
r1_in<=bus_8bit;
r3_in<=bus_8bit;
-- please attention r2 register input directly is connected to alu output
process(sel)
begin
case sel is
when "00" =>
bus_8bit<=r0_out;
when "01" =>
bus_8bit<=r1_out;
when "10" =>
bus_8bit<=r2_out;
when "11" =>
bus_8bit<=r3_out;
when others => null;
end case;
end process;
alu_arm1<=r1_out;
alu_arm2<=r2_out;
with opr select
alu_out<=alu_arm1 + alu_arm2 when "000",
alu_arm1 - alu_arm2 when "001",
alu_arm1 and alu_arm2 when "010",
alu_arm1 or alu_arm2 when "011",
alu_arm1 nand alu_arm2 when "100",
alu_arm1 xor alu_arm2 when "101",
not alu_arm1 when "110",
not alu_arm2 when "111",
"--------" when others;
end behavioral;
library ieee;
entity top_module_comm_bus is
end top_module_comm_bus;
architecture testbench of top_module_comm_bus is
constant t:time:=20 ns;
constant d:integer:=4;
constant dd:integer:=200;
signal r0_in,r1_in,r3_in:std_logic_vector(0 to 7);
signal r0_out,r1_out,r2_out,r3_out:std_logic_vector(0 to 7);
signal bus_8bit:std_logic_vector(0 to 7);
signal r0_clr,r1_clr,r2_clr,r3_clr:std_logic;
signal r0_ld,r1_ld,r2_ld,r3_ld:std_logic;
signal clk:std_logic;
begin
uut: entity work.comm_bus(behavioral) port map(r0_in=>r0_in,r1_in=>r1_in,
r3_in=>r3_in,r0_out=>r0_out,r1_out=>r1_out,r2_out=>r2_out,r3_out=>r3_out,
r0_clr=>r0_clr,r1_clr=>r1_clr,r2_clr=>r2_clr,r3_clr=>r3_clr,
r0_ld=>r0_ld,r1_ld=>r1_ld,r2_ld=>r2_ld,r3_ld=>r3_ld,clk=>clk,
bus_8bit=>bus_8bit,
opr=>opr,
sel=>sel);
-- 20 ns clock is running forever
process
begin
clk<='0';
wait for t/2;
clk<='1';
wait for t/2;
end process;
--clear all of registers and then released them
--process
--begin
--r0_clr<='0';
--r1_clr<='0';
--r2_clr<='0';
--r3_clr<='0';
--r0_ld<='0';
--r1_ld<='0';
--r2_ld<='0';
--r3_ld<='0';
--wait for d*t;
--r0_clr<='1';
--r1_clr<='1';
--r2_clr<='1';
--r3_clr<='1';
--wait;
--end process;
r0_clr<='0','1' after t;
r1_clr<='0','1' after t;
r2_clr<='0','1' after t;
r3_clr<='0','1' after t;
r0_ld<='1','0' after t;
r1_ld<='1','0' after t;
r2_ld<='1','0' after t;
r3_ld<='1','0' after t;
-- now for example we have two numbers one of them in r1 and another one in r2
-- at first we add them and put result in r0 and again do some logical operation
-- on two registers r1 and r2 and this time put the result in r3
process
begin
wait for d*d*t;
bus_8bit<="10011100";
wait for t;
r1_ld<='1';
wait for t;
r1_ld<='0';
opr<="000";
wait for t;
r2_ld<='1';
wait for t;
r2_ld<='0';
wait for t;
sel<="10";
wait for t;
sel<="--";
r0_ld<='1';
wait for t;
r0_ld<='0';
wait for t;
opr<="010";
wait for t;
r2_ld<='1';
wait for t;
r2_ld<='0';
wait for t;
sel<="10";
wait for t;
sel<="--";
wait for t;
r3_ld<='1';
wait for t;
r3_ld<='0';
wait for dd*d*t;
end process;
end testbench;
could you post your code inside code tags? that takes care of formatting, which makes it easier to read.
